therawski
Aug 30, 2017Guide
4G LTE Modem LB1120 extremely slow speed on T-Mobile
I recently picked up a Netgear 4G LTE Modem model LB1120 to use with my T-Mobile unlimited plan and when I plug the sim card in (from the phone that I'm not going to use anymore) I get extremely slow...
LGTurk
Dec 14, 2017Tutor
Thanks very much. This appears to have worked for the PC. I shut down the PC and cold restarted. The internet speed test still shows a high download value (approx 16 Mbps).
Now - my cellphone connected to the same network as the PC only shows about 0.5 Mbps. Does the PC command string only provide a fix for the PC and not other devices connected to network?
therawski
Dec 14, 2017Guide
The command I provided only changes the registry of your windows based PC. Your phone should already look like a phone on the T-Mobile network, but if you are connecting your phone to say your wifi router then the speed might be affected by that device, perhaps it's old or broken (I've had one die on me before). I would suggest not using the wifi and only using the data connection from T-Mobile.
