richardx73
Jan 29, 2016Aspirant
6100D Gateway Internet access problem
6100D gateway stopped working. Gateway was working fine. All of a sudden (I think) I started getting "Unidentified network/no internet access" indications from my PC. Tried a second PC with same resu...
- Feb 01, 2016
Problem solved. Apparently I didn't hold the reset button long enough. I did a quick reset with no improvement. Next I did a 5-6 second reset with no results. Looks like it takes 10+ seconds to get the proper results.
I don't know what caused the problem initially, but it's gone now. I'm happy.
DarrenM
Jan 29, 2016Sr. NETGEAR Moderator
Hello richardx73
Have you tried 192.168.1.1 or 192.168.0.1 to access the GUI? and have your tired both ethernet and wireless?
DarrenM
