richardx73's avatar
richardx73
6100D Gateway Internet access problem
6100D gateway stopped working. Gateway was working fine. All of a sudden (I think) I started getting "Unidentified network/no internet access" indications from my PC. Tried a second PC with same resu...
  • richardx73's avatar
    richardx73
    Feb 01, 2016
    Problem solved.  Apparently I didn't hold the reset button long enough.  I did a quick reset with no improvement.  Next I did a 5-6 second reset with no results.  Looks like it takes 10+ seconds to get the proper results.
    I don't know what caused the problem initially, but it's gone now.  I'm happy.
