up2itnow
Oct 01, 2015Guide
781s Freezing after a few hours
I'm using the Unite Pro 781S for home internet so I have it set to never go into standby mode but it seems to continue to stop working after a few hours and requires a reboot to begin functioning aga...
DarrenM
Oct 02, 2015Sr. NETGEAR Moderator
Hello up2itnow
Do you have the wifi profile set to default? to check this go to the WiFi tab then click options and a drop down should be beside wifi profiles try to change this to custom then make sure standby is off again and save the profile. I read in the user manual that if on default it could still standby. Hope to hear your feedback.
DarrenM
