rttttt
Aug 31, 2015Follower
781s limited connectivity when near other WiFi
When there is another WiFi near, unable to use connection to the AirCard 781S. Get "limited connectivity". Appears the 781S can use only one WiFi chanel. Unable to change to another WiFi chanel on the 781S. This happens FAR to often and makes this unit almost unusable as a mobile WiFi device. Any suggestions on how to change the WiFi Channel on the 781S?
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Rtttt
You can change the channel on the 781s I attached a screen shot on where to do this.
Let me know if this helps
DarrenM
