mathieu75000
Feb 12, 2020Follower
938 devices connected to my Netgear Router suddently
Hello,
I am having an issue with my router with some 939 devices connected that are not mine...
I m affraid i m being hacked somehow.
That number is getting higher and higher while i writte this message , 969 now
I don't know what to do
1 Reply
What router are you using?
Firmware on it?
What modem are you using?
What happens after a reboot?
Have you tried a factory reset and reinstall? Change the login password when you redo setup.
