Mikeyj1990
Feb 07, 2018Aspirant
Ac1200 c6220
I have a c6220 and after a recent power outage, i have lost the wired connection. At this time i have reset the devices that are wired, replaced wires, performed factory reset both ways (button and o...
Mikeyj1990
Feb 13, 2018Aspirant
Any info here?
- JasonNFeb 14, 2018NETGEAR Employee Retired
Hi Mikey1990,
I see that you have tried some troubleshooting yourself. Please try these steps below if you haven't waited that long for the reset.
1. Remove "All" power supplies and network cables.
2. Let the Modem and Router sit for 30 mins.
3. Power up the modem until it is fully up.
4. Wire the router and then power up.
Please let me know if this has fixed the issue. :]
- Jason N
- JasonNFeb 20, 2018NETGEAR Employee Retired
Hi Mikeyj1990,
I wanted to check up on you and see if the steps worked for you. Please let me know :]
- Jason N
- Mikeyj1990Feb 21, 2018AspirantThis did not help. The wired connection is still not working
- JasonNFeb 21, 2018NETGEAR Employee Retired
Hi Mikeyj1990,
We confirmed that you have tried resetting the device, replaced the wires,
and performed factory resets.
Please contact the NETGEAR Tech Support line for further assistance on this issue.
- Jason N
