Mikeyj1990
Feb 08, 2018Aspirant
Ac1200 c6220
I have a c6220 and after a recent power outage, i have lost the wired connection. At this time i have reset the devices that are wired, replaced wires, performed factory reset both ways (button and o...
Mikeyj1990
Feb 14, 2018Aspirant
Any info here?
JasonN
Feb 20, 2018NETGEAR Employee Retired
Hi Mikeyj1990,
I wanted to check up on you and see if the steps worked for you. Please let me know :]
- Jason N
- Mikeyj1990Feb 21, 2018AspirantThis did not help. The wired connection is still not working
- JasonNFeb 21, 2018NETGEAR Employee Retired
Hi Mikeyj1990,
We confirmed that you have tried resetting the device, replaced the wires,
and performed factory resets.
Please contact the NETGEAR Tech Support line for further assistance on this issue.
- Jason N
- Pacific_NWApr 12, 2018Tutor
I am having the same issue here - but it is only Port 1 that is not working. Port 2 works fine and connects a Gigabit Ethernet Switch that has a bunch of other devices plugged in. I tried the power off option (which is a big PITA since I work from home and need to be online for work) but only for 5 minutes and not the full 30 minutes. I have tried cable swaps etc.,. and to no avail.
