Mikeyj1990
Feb 07, 2018Aspirant
Ac1200 c6220
I have a c6220 and after a recent power outage, i have lost the wired connection. At this time i have reset the devices that are wired, replaced wires, performed factory reset both ways (button and o...
JasonN
Feb 21, 2018NETGEAR Employee Retired
Hi Mikeyj1990,
We confirmed that you have tried resetting the device, replaced the wires,
and performed factory resets.
Please contact the NETGEAR Tech Support line for further assistance on this issue.
- Jason N
Pacific_NW
Apr 12, 2018Tutor
I am having the same issue here - but it is only Port 1 that is not working. Port 2 works fine and connects a Gigabit Ethernet Switch that has a bunch of other devices plugged in. I tried the power off option (which is a big PITA since I work from home and need to be online for work) but only for 5 minutes and not the full 30 minutes. I have tried cable swaps etc.,. and to no avail.
- JasonNApr 18, 2018NETGEAR Employee Retired
Hi Pacific_NW,
Is your AC1200's firmware up-to-date with the most current version?
Please let me know. :]
- Jason N
- JasonNApr 23, 2018NETGEAR Employee Retired
Hi Pacific_NW,
I just wanted to check in with you and see if your issue has been resolved?
- Jason N
