Colddiver
Dec 30, 2015Follower
AC340U (AT&T Beam) Windows 10 Firmware will not load.
Anybody had any luck in getting this firmware to load? Mine gets to about 98% and fails.
DarrenM
Jan 05, 2016Sr. NETGEAR Moderator
Hello Colddiver
Have you tried to factory reset the device and then update the firmware?
DarrenM
bwilburn
Jun 16, 2016Aspirant
how do you reset back to factory settings? I can't figure out how to get it to a mode to accept AT commands. It shows up as a network interface and not a com port in device manager.
