kkinderen
Jan 06, 2017Aspirant
AC781S and Windows 10
I tried to tether the AC781S to Windows 10. I installed the NETGEAR AC718S Driver Package. This was probably not a good idea. The package installed but things have become very slow on the compute...
DarrenM
Jan 11, 2017Sr. NETGEAR Moderator
Hello KKinderen
I have seen where running the ATT software and the Netgear software at the same time has caused issues with the aircards if you have ATT software try to stop that from running and see if that helps.
DarrenM
kkinderen
Jan 11, 2017Aspirant
Hi Darren:
I'm running no specific software related to the hotspot. Is there something I should have installed?
When I plug in the Unite Pro and check network adapters in device manager I see a new NDIS device.
Maybe there's specific Windows 10 drivers I should be installing but I haven't found where they could be.
Thanks,
Kevin
- DarrenMJan 13, 2017Sr. NETGEAR Moderator
Hello kkinderen
You can try to use aircard watcher see if that works.
http://downloadcenter.netgear.com/en/product/AirCard%20320U%20(Telstra)#searchResults
DarrenM
