kkinderen
Jan 06, 2017Aspirant
AC781S and Windows 10
I tried to tether the AC781S to Windows 10. I installed the NETGEAR AC718S Driver Package. This was probably not a good idea. The package installed but things have become very slow on the compute...
kkinderen
Jan 11, 2017Aspirant
Hi Darren:
I'm running no specific software related to the hotspot. Is there something I should have installed?
When I plug in the Unite Pro and check network adapters in device manager I see a new NDIS device.
Maybe there's specific Windows 10 drivers I should be installing but I haven't found where they could be.
Thanks,
Kevin
DarrenM
Jan 13, 2017Sr. NETGEAR Moderator
Hello kkinderen
You can try to use aircard watcher see if that works.
http://downloadcenter.netgear.com/en/product/AirCard%20320U%20(Telstra)#searchResults
DarrenM
