DanIAm's avatar
DanIAm
AC785 One Click Firmware update doesn't work
I can't get the One Click Firmware update utility to work. It runs, says it's connecting, downloading firmware and flashing successfully, but the firmware doesn't actually get upgraded. I don't believe it is actually downloading any firmware, as that step takes just a fraction of a second and I see no firmware file in the AppData\Loca\Temp\FDT folder where the rest of the installer gets extracted to. I've tried while my PC is on WiFI and a wired Ethernet connection, but neither work. The previous firmware update is a monolithic file (doesn't try to download the latest update on the fly), and that works fine.
Teh dirver and firmware update files were downloaded from here: http://netgear.com/support/product/ac785.aspx#download , but unfortunately there are no dates to know how recent they are.
Any ideas?
  • JasonN's avatar
    JasonN
    NETGEAR Employee Retired
    Hi DantAm,
    Can you please PM me with firmware // PRI # // Sku # // etc. to me.
    What troubleshooting have you done?
    Please provide your contact information.
    Thank you. :]
    - Jason N
    • DanIAm's avatar
      DanIAm
      Sorry have been busy and have only just seen your messages. I'll dig the info out, but probably won't be able to respond until Friday.
      • JasonN's avatar
        JasonN
        Hi DanIAm,
        Thanks for the response! That is fine. Just send the information to me as soon as you can and we'll move forward from there. :]
        - Jason N
  • JasonN's avatar
    JasonN
    Hi DanIAm,
    I am still waiting for you to PM me with the information I have requested.
    Please let me know. :]
    - Jason N
