Retired_Member
Jun 19, 2016AC790 and an USB to Ethernet adapter
What chipset does AC790 feature? With what USB-to-ethernet adapter will it automatically work, i.e. what model will be out-of-the-box supported by AC790's kernel? Netgear's own cradle uses such a mec...
nippit
Sep 01, 2016Aspirant
I agree with the OP.
the base is connected the same way. so if we can identfy the chip in teh base same chip will work as usb ethernet adapter.
this is all to do with installed drivers in the kernel not related teh CPU or other chips.
any one has the base DC112A or DC113A can they plug it into a PC and identfy chipsets?
cheers
