uga_fan13
Feb 07, 2016Initiate
AC791l and DC113a. I cannot get the cradle ethernet port to work
I am having issues with my dc113a. I purchased the DC113a a couple of weeks ago to use with my Netgear AC791l. When I put the hotspot in the cradle, the hotspot will charge; however, the ether...
DarrenM
May 09, 2016Sr. NETGEAR Moderator
Hello Jack_T_Chance
It could be a compatibility issue as the Dc113a does not fully support the AC791L here is the list of compatible devices.
https://kb.netgear.com/app/answers/detail/a_id/26864
DarrenM
Jack_T_Chance
May 09, 2016Guide
Well, DarrenM, that's quite a convenient change in the compatibility statement to make several months after Netgear discontinued the DC113A. While the DC113A was still readily available, both Netgear.Com and Verizon Wireless' own website listed the DC113A as a fully-compatible accessory for the AC791L. So, what you're now stating is that, in effect, Netgear LIED TO US about the compatibility of the DC113A? :smileyfrustrated:
The problem here isn't the DC113A Cradle. It was designed to be fully compatible with ALL North American and European Netgear Air Card models available at the time of its release, and all FUTURE models that would come out after it was released, which includes the AC791L. The problem here is the FAULTY FIRMWARE FOR THE AC791L which still hasn't been updated since release, because Verizon Wireless is delaying the Firmware Update with their unnecessarily long Carrier Certification Process. It should NOT take months or in some cases YEARS after the Firmware Update is sent to VZW for that Update to be released to the End Users of the Air Cards. The fact that it does is totally Verizon's fault, and is something that Netgear SHOULD be working with VZW to resolve. :smileymad:
EDIT: DarrenM, it also states quite clearly on THIS NETGEAR PRODUCT COMPATIBILITY PAGE that the DC113A is compatible with "NETGEAR AirCard 79xS Products". The Verizon Wireless Jetpack AC791L is part of that "79xS" series of Air Cards. So, you didn't even direct us to the correct Product Compatibility Page. *Shaking My Head*
