uga_fan13
Feb 07, 2016Initiate
AC791l and DC113a. I cannot get the cradle ethernet port to work
I am having issues with my dc113a. I purchased the DC113a a couple of weeks ago to use with my Netgear AC791l. When I put the hotspot in the cradle, the hotspot will charge; however, the ether...
antennamatt
Mar 09, 2017Aspirant
Purchase the Micro to Ethernet adapter:
Plugable USB 2.0 OTG Micro-B to 10/100 Fast Ethernet Adapter for Windows Tablets & Raspberry Pi Zero (ASIX AX88772A chipset) https://www.amazon.com/dp/B00RM3KXAU/ref=cm_sw_r_cp_apip_LsB1XR9OgwTDx
JoeBenya
Aug 17, 2017Aspirant
There is a problem with this solution as an alternative to the cradle - the adapter does not charge the AC791L battery (unlike the cradle). So it cannot act as a permanent ethernet port out. It must be removed for recharging daily. So, great solution for road warrior, but not one looking for a permanent hotspot to ethernet connection for home use (such as in a rural internet setup).
