dnyberg2's avatar
dnyberg2
Follower
Apr 29, 2017
AC791L boosters and cradles...
I read on the internet that DC112A cradles work with the AC791L from Verizon.  Any one know if this is true?
If not, do DC113's work with the AC791L?
Does anyone have an AC791L working on any cradle and if so which one's??
Does anyone have an AC791L working with any kind of cell booster and MIMO antenna?
If so, what MFG and model are you using and how much better does it do for you?
Does anyome know for sure how these cradles boost the Wifi signal?
If the two "accessory ports" on the unit are both for MIMO cell antenna operation, how does a cradle boost the Wifi Signal without a coax connection and or external Wifi antenna??
Thanks, Dave
