jcgc50
Oct 25, 2017Follower
AC79l Keeps Shutting Off
I'm using the AC79L wireless hotspot and it randomly shuts off whether it's plugged in or running on battery. Status of charge seems to make no difference. It has shut down three times so far today.
Checking settings I see nothing that would cause it to shut down automatically. Firmware is current.
Any suggestions as to the problem and solution?
1 Reply
- DarrenMSr. NETGEAR Moderator
I suggest contacting the ISP you got the unit from or contacting Netgear support.
http://www.netgear.com/support/contact.aspx
DarrenM
