Genr's avatar
Genr
AC800. New battery needed
I'm in Queensland Australia and need a new net gear w7b battery. For my AC800.
for the life of me I cannot find any. I bought a no name battery today but it doesn't work. Any ideas please
Thanks
  • Genr's avatar
    Genr
    Mar 25, 2021
    I found one on eBay. It works. The only advertisement that says the battery will work in an AC 800 Optus
    Thanks
    I am also facing exact same issue. Is your issue resloved? any recommendation how to solve this issue.? Can any one please help?
    myindigocard
    • michaelkenward's avatar
      michaelkenward
      You have posted your message in the section of this community given over to
      Nighthawk WiFi Routers.
      (This is easily done, given Netgear's complicated community structure.)
      Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
      Mobile Routers, Hotspots & Modems
      I will ask the Netgear moderator to move your message.
      • Genr's avatar
        Genr
