Gokio
Aug 02, 2017Aspirant
AC800S Compatibility with Netgear Cradle DC112A
I have recently puchased the new AC800S (Optus) and I needed to boost the Wifi and the LTE signal so I puchased a DC112A (Firmware V1.0.0.30_1.0.60) which said it was compatable with most Aircards – ...
- Nov 07, 2017
Hi everbody, I can confirm that the cradle now works with the AC800s. A software update arrived today for the AC800s and straight after the update I put it in the cradle and all lights are green. Works great!
Good luck!
DarrenM
Aug 15, 2017Sr. NETGEAR Moderator
yes this aircard should work with the dock.
DarrenM
- GokioAug 15, 2017Aspirant
I know that it should work, however it doesn't work.
The Aircard doesn't recognise the base at all or bridge the wifi networks. It simply uses it as a charging station & potentially the LTE antenna works but I can't confirm this. Hopefully a fireware update will be out soon for either device. - ROCCASAug 17, 2017Tutor
Hi DarrenM,
Do you have any more information on when the new firmware may be coming?
