Gokio
Aug 02, 2017Aspirant
AC800S Compatibility with Netgear Cradle DC112A
I have recently puchased the new AC800S (Optus) and I needed to boost the Wifi and the LTE signal so I puchased a DC112A (Firmware V1.0.0.30_1.0.60) which said it was compatable with most Aircards – ...
- Nov 07, 2017
Hi everbody, I can confirm that the cradle now works with the AC800s. A software update arrived today for the AC800s and straight after the update I put it in the cradle and all lights are green. Works great!
Good luck!
DarrenM
Aug 15, 2017Sr. NETGEAR Moderator
yes this aircard should work with the dock.
DarrenM
Gokio
Aug 15, 2017Aspirant
I know that it should work, however it doesn't work.
The Aircard doesn't recognise the base at all or bridge the wifi networks. It simply uses it as a charging station & potentially the LTE antenna works but I can't confirm this. Hopefully a fireware update will be out soon for either device.
