Gokio
Aug 02, 2017Aspirant
AC800S Compatibility with Netgear Cradle DC112A
I have recently puchased the new AC800S (Optus) and I needed to boost the Wifi and the LTE signal so I puchased a DC112A (Firmware V1.0.0.30_1.0.60) which said it was compatable with most Aircards – ...
- Nov 07, 2017
Hi everbody, I can confirm that the cradle now works with the AC800s. A software update arrived today for the AC800s and straight after the update I put it in the cradle and all lights are green. Works great!
Good luck!
RayZef
Aug 18, 2017Aspirant
It would be nice if Netgear would comment on our problems with compatability of the 800S ans DC112A cradle.
Will you be dipporting the combination? If yes when can we expect the upgraded firmware.
Will both devices need firmware upgrades?
Do you only support Telsta with your DC112A and not allowed to support Optus?
Thanks
cmar8335
Aug 21, 2017Aspirant
netgear mods!!!
any update on this thread?
- GokioAug 21, 2017Aspirant
I've got a fiver that says Netgear don't have mods.. I'll raise that five to bet that we never get an answer on the old DC112A or the AC800S –– so perhaps we could start coding our own firmware to support the dinosaur Netgear.
