JeanetteSeymour
Oct 12, 2016Aspirant
AC810 - Hungry on internet
I have recently bought the AC810 after having endless problems with the AC785. I was told it was a bit slow and to upgrade to the AC810. Anyhow, whilst it may be a bit faster (not impressively fa...
DarrenM
Oct 19, 2016Sr. NETGEAR Moderator
Hello JeanetteSeymour
When using the aircard are you using other devices on wifi and not the Ipad or are you just using the Ipad when you use the aircard?
DarrenM
JeanetteSeymour
Oct 20, 2016Aspirant
Hi. DarrenM,
I am using iPad and 11" Macbook. Thanks, Jeanette
