lorensiah's avatar
lorensiah
AC810 restart issue
HI,
I have installed the latest firmware on the AC810 , when its connected to 4G network and i use it with PC or phone , it restart ramdomly I dont know why?
I have too reconfigure with factory reset ...Same issue
REgards
Lorensiah
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Please make sure you used a battery with it and check whether that makes any differences.
    Thanks
    • lorensiah's avatar
      lorensiah
      Hi
      It s connected with his power supply or over USB on PC... So it s always 100% ( charge about battery)
      Regards
      Laurent
