pustynnyjez
Oct 02, 2016Initiate
AC810s common issues
Hi, does anyone knows what's the issue, that this router is rebooting each time when the network traffic is bigger than just watching youtube ? downloading big file (like iso image from torrent netw...
Holiven
Nov 30, 2016Guide
Hello
Any update about this issue?
It's very annoying because i lost connection very often
- Jake_Dec 11, 2016Aspirant
Hi all,
I did some testing with few configuration. Here are my observations:
1. when using my VPN connection with UDP setting ac810s tends to freeze after few seconds (3-4 active torrent connection)
2. when using my VPN connection with TCP setting ac810s works fine but active connection has to be limited to 3-4. From time to time connection freezes but device restart is not needed - so VPN using TCP is some workaround - anyway with this setup connection is rather slow - up to 1.5 Mbytes/s
Without VPN ac810s router seems to be working fine. Maybe VPN providers use bigger frames? Anyway with ac810s this is first time I experienced freezing issue. Number of potential ac810s buyers is narrowing, having in mind VPN usage will be growing.
