pustynnyjez
Oct 02, 2016Initiate
AC810s common issues
Hi, does anyone knows what's the issue, that this router is rebooting each time when the network traffic is bigger than just watching youtube ? downloading big file (like iso image from torrent netw...
olkitu
Jul 31, 2017Star
I have Netgear AC810 also and have similar issue with OpenVPN UDP, first disconnect and then reboot.
Model: AirCard 810S
Firmware VersioN: NTG9X40C_11.14.08.20
Firmware Build Date: 2017/03/26
Hardware Version 1.0
PRI Version: 02.07
Web App Version: AC810S-1.03.03.103.155
georg11
Jan 05, 2018Aspirant
I just registered to say thank you for describing these problems -- I'm a common VPN user. As NetGear hasn't had the decency to fix this issue, I'm not buying this product. Also, the reheating issues you mention worry me.
Cheers,
