Ukeee's avatar
Ukeee
AC810s Firmware Upgrade not working
I have an Aircard 810s
I am unable to initiate firmware update on my ac810s as it kept giving me an Update Error message.
Firmware Version:NTG9X40C_10.13.02.00Firmware Build Date:2015/09/03
  • Hi Ukeee,
    Thank you for responding. Please reset the unit one more time and try again. Where did you purchase the unit?
    Blanca
    Community Team
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Ukeee,
    Welcome to NETGEAR Community!
    As I understand, you are unable to update the firmware. May I ask for the following information:
    - What Internet browser (and version) did you use to open the device page?
    - Have you tried to use another computer/device to upgrade the firmware?
    - Have you tried to use another Internet browser?
    - Have you tried to reset the device?
    Please make sure that you have good signal when you update the firmware.
    Blanca
    Community Team
    • Ukeee's avatar
      Ukeee
      I've used Microsoft Edge (42.17134.1.0) and Mozilla Firefox (61.0b11)
      I have tried to use the Netgear app on my iPhone and it still would not update the firmware version
      Yes as mentioned above
      Do you mean to reset it back to default factory settings? Yes I did initially do a factory reset when I first got the AC810s.
      • Blanca_O's avatar
        Blanca_O
        Hi Ukeee,
        Blanca
        Community Team
