GShipley_NC's avatar
GShipley_NC
Initiate
Nov 09, 2018
AC815S inop. Amber light blinking 4 times and then shuts down
Plugged my ATT AC815s in to charge overnight and today it will not turn on. I press the "on" button and the LED blinks orange about 4 times and then shuts itself down. When I try to plug it in and turn it on, the initial sequence cycles over and over. I've taken the battery out, waited a while, and replaced it. Right now, the hotspot is a brick. Why?
  • Problem solved. I purchased a new battery and the hotspot works again. :)
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi GShipley_NC
    Welcome to NETGEAR Community!
    Please contact your ISP to perform hardware check.
    Blanca
    Community Team
    • GShipley_NC's avatar
      GShipley_NC
      Initiate
    • Blanca_O's avatar
      Blanca_O
      Hi GShipley_NC
      Great! Glad to know that it is working.
      Blanca
      Community Team
