msfox99
Sep 24, 2021Guide
Accessing admin panel after enabling bridge mode
Hi - my setup is: Combined cable modem/router Xfinity box--->Netgear router (miscellaneous). I have this setup to use the cable modem inside the Xfinity box, and then the Netgear router as a Wif...
msfox99
Sep 29, 2021Guide
Thanks to you michaelkenward and plemans for your replies. They are helpful. And thanks for pointing out the incorrect forum, I missed that.
michaelkenward
Sep 30, 2021Guru - Experienced User
It really isn't that important. Many questions are generic. It just helps to look in the device specific sections if you need to take things further.
