endriu
Jul 25, 2016Tutor
After (forced) FW upgrade AirCard 785S enters boot loop with the battery pulled out
My router forcefully upgraded itself today to the following firmware: FW Version:NTG9X25A_02.14.04.13 FW Build Date:05/03/16 Web App Version:AC785S-1_03.03.103.110 Bootloader Version:NTG9X25A_...
navisence
Aug 05, 2016Aspirant
I have the same issue. This is a problem since I intended to use the aircard without the battery.
Bought the device yesterday - it booted fine without the battery inserted. Then did the recommeded firmware update. Now the device sits in a boot loop when only connected to the included USB power supply.
- endriuAug 05, 2016Tutor
I found a workaround for this issue. Start the router connected, with the battery in. Set everything up, enable data transmission, etc. Let it run for a few seconds like that and then pull the battery out. It should stay up. If you do it too early it will enter the boot loop.
Still I would like to raise it as an issue to the manufacturer so that it could be solved in the next firmware version. Anybody knows how to do it?
- ender1Oct 14, 2016Aspirant
me too I would confirm this issue, I recently bought this router from Amazon, model is AC785-100EUS
and hardware revision is 1.0. I do not remember which version of firmware was when I turned it on the first time.
I then successfully configured and started to navigate through it without battery inserted but just plugged in to
the wall because the intent was to use it as a permanent 24/24h connection, and all worked very fine for just a couple of minutes;immediately later, infact, an update become available and I decided to install it, but when the updated finished
the router started an infinite boot loop. I immediately thought the update didn't worked and the unit was
irremediably fired, but after some hours of attempts I tried to insert the battery again and this time the router
succesfully booted. The firmware is now:
FW Version:
FW Build Date:
05/03/16
Web App Version:
Bootloader Version:
Hardware Version:
1.0
TRU-Install:
PHS_B4045
The workaround of removing the battery while the router is turned on, as suggested by an user on this thread,
it absolutely does not work with my unit, if I try to remove the battery the router immediately reboots itself
and it starts again an infinite loop until you insert again the battery.Another issue I have noticed is that the GUI continues to advise me that an update (of 69 mb) is available,
even if I have already succesfully installed it before: after that you have finished to install it, the router normally reboots, but when you open the GUI and you check if a new update is available the GUI propose to install it again. And so on forever.Greetings
