Gregg3821's avatar
Gregg3821
Follower
Jul 18, 2016
Air Card 815S I need a new AC Adapter HELP HELP HELP
I need to buy a new AC Adapter. Please help. I have lost the OEM one and no aftermarket charger will work. My air card is dead in the water without a new adapter. PLEASE HELP. I am willing to buy one today, just need to know where to get it from.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Gregg3821
    You will want a power adapter that can output 5volt 1amp to charge the aircard you may want to check your cell phone charger plugs and see if they will work.
    DarrenM
