jkershner's avatar
jkershner
AirCard 313U (AT&T) not recognized on Windows 10 machine
Tested AirCard works fine on Windows 7 machine Insert AirCard into Lenovo X1 Carbon laptop - AT&T All Access app shows "modem unplugged" when it is inserted into USB port. Contacted AT&T support th...
  • DarrenM's avatar
    DarrenM
    Sep 17, 2015
    Jkershner
    Thank you for the screen shots. Have another thing we can try to do is Click on your windows/start button go to File Explorer then on the left hand side Click This PC on this screen you should see Devices and Drives If you see a Drive named AT&T or tru-install Right click on it and then select eject once this ejects see if Windows 10 sees and installs the aircard. If it is still not detected you can use the Netgear Aircard Watcher install this and check to see if the aircard is detected and working. Here is the link to download Aircard Watcher.
    http://www.downloads.netgear.com/files/aircard/AC340U/Watcher_Generic_UM.msi
    Let me know if this works
    DarrenM
