discochicken
Sep 21, 2016Tutor
AirCard 313U on MacOS Sierra
I've been happily using the AT&T branded AirCard 313U on MacOS X with my AT&T account. I upgraded yesterday to MacOS Sierra, and the card is no longer working. I've re-installed the AT&T AllAccess ap...
- Sep 22, 2016
Hello discochicken
Try to use the Netgear watcher program you may even want to close out the ATT software to see if it will detect the 313U.
DarrenM
DarrenM
Sep 22, 2016Sr. NETGEAR Moderator
Hello discochicken
DarrenM
discochicken
Sep 24, 2016Tutor
Thanks DarrenM. AirCard Watcher is working for me!
