areyouawizard's avatar
Jan 13, 2016
Aircard 320 U card with 313u driver
Hello
I am having an issue with the telstra 4g  320u sierra wireless card.
When i attached the device it will not show up to connect in the telsta manager as being available.
However, if i use a program called iPass which helps switch between mobile,wireless and wired connections the device is not visiible to connect but in the settings it has 2 drivers available.
As soon as i select the 320u driver as prefered it will come up in both ipass and telstra manager then i can connect without issue, but i have to do this procedure everytime i restart my laptop.....
Is there a way i can remove the 313u driver and just have the 320U WWAn???
i cannot find it in admin tools in device manager.
Telstra Aircard 320U qualcomm 3g
Windows 7 pro 64bit
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello areyouawizard
    Yes I would try to remove one of the drivers because they could be conflicting with each other.
    DarrenM
