IJustKnowStuff
Mar 12, 2019Follower
Aircard 320U not compatible with Windows 10 Device Guard
It seems the drivers for the Aircard 320U are not compatible with Windows 10 when Device Guard is enabled.
The drivers appear to get blocked from loading and detecting the device. I can disable and...
Blanca_O
Mar 13, 2019NETGEAR Employee Retired
Welcome to NETGEAR Community!
Our support team is looking into this and would like to work with you. Please check your inbox.
Blanca
Community Team
