LgModem
Feb 25, 2015Novice
Aircard 320U Unsolicited Response -Enable
Hi, I have connected to /dev/ttyUSB2 (AT port) of AirCard 320U in Linux through minicom . But not getting Unsolicited responses like RSSI etc . Is there any specific AT command to enable Unsol...
apac_se
Jun 01, 2015Apprentice
Hi LgModem,
I have also seen how the Huawei USB modems automatically display signal strength info but the NETGEAR modems do not have such a feature to enable. You can try using at!gstatus in a script to obtain the signal strength periodically.
Kind Regards,
Arodi
Kind Regards,
Arodi
