lageotakes
Apr 28, 2018Aspirant
AIRCARD 340u Turn On Identity Morphing
I turned off Identity morphng when I was trying to installed the usb modem in linux. Is tehre a way to turn it back on. i turned it off by following these directions
https://kb.netgear.com/26983/AirCard-340U-AT-T-Beam-Downloads-and-Documentation
AC340U Documentation and Drivers for Enabling Linux Support
Step 1 – Turn Off Identity Morphing
To turn off device identity morphing used with Windows 8, download and run the AC340U_linux_patch_v4.exe configuration utility at the support.netgear.com support site.
http://www.downloads.netgear.com/files/aircard/AC340U_linux_patch_v4.zip
To run the tool on a Windows 7 PC:
Install the necessary drivers on your Windows PC (if not already completed)
Insert device, make sure no AT&T or other connection manager is running.
Execute “AC340U_linux_patch_v4.exe”
After the tool completes, you should notice your device reset & connected status on the LCD.
Note that this change will turn OFF Windows 8 native MBIM support, so please consider this when you make your update.
1 Reply
- JasonNNETGEAR Employee Retired
Hi lageotakes,
Can you please PM me with firmware // PRI // Sku // etc. to me.
What troubleshooting have you done?
Please provide your contact information.
Please be detailed as I will be forwarding this to my internal team for further assistance. :]- Jason N
