michi0123
Jan 19, 2016Aspirant
Aircard 762s dead
hey guys, i just wanted to use my aircard 762s again after a few month not using it, but as i want to start it, it wont boot up - not even if the a/c is conncted! it is really really strange!!! ...
DarrenM
Jan 20, 2016Sr. NETGEAR Moderator
Hello Michi0123
I would suggest trying a factory reset on the device you do this by holding down the power and the WPS button at the same time for 10 seconds. If this does not work the screen could be bad and if your still under warranty I would suggest calling your provider.
DarrenM
michi0123
Jan 28, 2016Aspirant
hey,
thanks for your answer!
i already tried a f/r, didnt work either! the screen just turns on w/o any stuff get displayed, and turns off - and so on, and so on... thats all. :(
