jambo1979
Mar 06, 2015Novice
Aircard 762S Strange Roaming Issue
Hi All, I am having a strange roaming issue (outlined below) which I would be grateful anyone can offer some assistance with. I bought my Netgear Aircard 762S from three (Ireland) approx 14 mon...
jambo1979
Mar 13, 2015Novice
apac_se wrote: Hi There,
It sounds as though the APN profile used is only for WAP access. You need to obtain the APN for Mobile Broadband access and make sure this APN is also provisioned on your SIM card. Quick google search tells me that the mobile broadband APN for 3 UK is 3internet
HI apac_se,
Many thanks for the reply - as I mentioned in my original post I am using the same APN as my 4g phone which works fine. (I have tried using APN's 3ireland.ie and 3internet
To add to this we have a lot of mobile workers in the UK (Using Dongles and 4G Routers) and I am using the same APN (3ireland.ie) as them.
3ireland.ie is now the main APN for Irish Accounts both at home and roaming
