Goodwill_Hobo
Oct 18, 2015Follower
AirCard 763 - DNS Manual Settings
Problem: I cannot reconnect after setting up OpenDNS on my AirCard 763S. What I did: I connected to the AirCard device through my computer and selected DNS Mode - Manual instead of Auto. It th...
DarrenM
Oct 19, 2015Sr. NETGEAR Moderator
Hello Dave
Have you made sure the default gateway Ip hasnt changed you can check that with ip config /all in your command prompt or you can use these links based on your provider.
DarrenM
