sb003848's avatar
sb003848
AirCard 763S compatible router
Hello,
I'm using my Netgear hotspot Aircard to connect my iPhone and AppleTV but the data transfer speed between the 2 devices is pretty slow so I'm wondering if there is a wireless router compatible with my Aircard in order to speedup the data transfer between the 2 devices ?
Thanks !
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Sb003848
    As of right now Netgear does not have a device that can do this for your Aircard.
    DarrenM
    • sb003848's avatar
      sb003848
      Thank you for the answer...
      In this case, is it possible to connect my Aircard via USB cable to a wireless router ?
      Thanks !
      • DarrenM's avatar
        DarrenM
        Hello sb003848
        You may be able to find a router on the market that can do that but we do not have one.
        DarrenM
