C4E
Nov 24, 2015Tutor
Aircard 785 Battery Will Not Charge, Cannot Find Spare Battery
Aircard 785 is just over six months old. Battery is unresponsive, won't charge at all - when connected to PC or mains via USB the screen shows either battery 0% or the red plug icon suggesting it's ...
Goodie0806
Nov 24, 2016Aspirant
I have a similar paroblem. The Aircard will work good on AC power however it would not charge the battery. I have replaced the battery with a new battery however when I connect to power the battery will not charge. The unit just displays the connected to AC icon (red plug). How can I get this device to start charging a brand new battery?
DarrenM
Nov 29, 2016Sr. NETGEAR Moderator
Hello Goodie0806
I would contact support if your battery is not charging and the unit is still under warranty.
http://www.netgear.com/support/contact.aspx
DarrenM
- Goodie0806Nov 30, 2016Aspirant
Thanks for the response. I took the device into the local Telstra shop, they are arranging for it to be fixed. (I hope).
