C4E
Nov 24, 2015Tutor
Aircard 785 Battery Will Not Charge, Cannot Find Spare Battery
Aircard 785 is just over six months old. Battery is unresponsive, won't charge at all - when connected to PC or mains via USB the screen shows either battery 0% or the red plug icon suggesting it's ...
DarrenM
Nov 29, 2016Sr. NETGEAR Moderator
Hello Goodie0806
I would contact support if your battery is not charging and the unit is still under warranty.
http://www.netgear.com/support/contact.aspx
DarrenM
Goodie0806
Nov 30, 2016Aspirant
Thanks for the response. I took the device into the local Telstra shop, they are arranging for it to be fixed. (I hope).
