JeanetteSeymour
Sep 25, 2016Aspirant
Aircard 785 connection problems on iPad and MacBook Air
I have an Aircard 785 which was working perfectly with my iPad and MacBook Air. After being away and not using the 785 for one month it does not work as it did previously despite not making any chang...
moriwi
Sep 28, 2016Aspirant
I have a Netgear 785s and have issues that only seems to manifest under certain conditions.
MacBook Pro (Retina, 15-inch, Mid 2015)
I used 'nettop tcp -d' on the mac to monitor connections.
All Connection are 802.11N
Netgear + Macbook Pro on built in WiFi - major latency.
Netgear + Macbook Pro USB - No issues
Netgear + Airport Express -- Ethernet on Macbook - No issues
Netgear + PC (Win 7) WiFi (TP-Link TL-WN721N) - No issues.
Netgear + PC (Win 7) USB - No Issues
I also have a ZTE MF60 that connects to the WiFI on the Macbook (802.11g )with no issues.
The issue seems to be with the connection between the AirPort Extreme and the Netgear 785s radios.
Macbook WiFi hardware info
en0:
Card Type: AirPort Extreme (0x14E4, 0x152)
Firmware Version: Broadcom BCM43xx 1.0 (7.21.95.175.1a6)
MAC Address: a4:5e:60
Locale: ETSI
Country Code: AU
Supported PHY Modes: 802.11 a/b/g/n/ac
Supported Channels: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 36, 40, 44, 48, 52, 56, 60, 64, 100, 104, 108, 112, 116, 132, 136, 140, 144, 149, 153, 157, 161, 165
Wake On Wireless: Supported
AirDrop: Supported, Channel 149
Status: Connected
JeanetteSeymour
Sep 30, 2016Aspirant
Thanks for your feedback Moriwi ... will look in to these issues.
