Help
4 TopicsCannot get router to reconized LB2120 in wan
LTE 4g Modem LB 2120 Modem works great on AT&T whe connected on LAN side but when connected to any router by WAN port, it is not reconized. Tried in Bridge mode but no go. It is being advertised to work with a router but I have not found any setup instructions for this purpose nor have I found anyone who has every got it to work this way.Aircard 785 connection problems on iPad and MacBook Air
I have an Aircard 785 which was working perfectly with my iPad and MacBook Air. After being away and not using the 785 for one month it does not work as it did previously despite not making any changes to settings. Whilst the 785 shows connection to IP with full signal, both devices will only operate for a few minutes (1-5) and then freeze up even though the devices as showing full signal too. The only way to get connection back is to restart the 785 which after 5+ times an hour becomes rather frustrating. Any suggestions would be greatly appreciated. Just a further note ... I have tried the SIM just in the iPad and it works perfectly!AT&T Unite/Aircard 0B78 Netgear
I have a Unite 0B78 (AT&T) Aircard by Netgear that started in September 2016 connected to IMAC and Iphone incorrectly using data. I have had the device about 3 years. I live in TDS rural area in Indiana. Is the device defective in using large amounts of data now or is the problem AT&T?
