Help
67 TopicsReadynas RND-6a doesn't boot
I got this NAS used and so am unsure as to how it works. The model is Readynas rnd-6a. When I power it on the fans spin up and "ReadyNAS" displays on the LCD but that is all. I assume it doesn't boot although I don't know how to check if it's online, I have plugged in an Ethernet cable and it doesn't show up on my router. So far I have tried: Removing all the disks External power supply Changing the memory There is no data it, I just want to resurrect the machine. Any info or solutions would be greatly appreciated. Thanks, ConnorSolvedNew C7100V took a nose dive - slow DL speed/normal upload
Model Number: c7100v Firmware: V2.01.33 OS: Mac High Sierra v10.13.3 Hi guys. I purchased the Nighthawk c7100v dual modem/router so I could stop paying the rental fee through comcast, and it works with the triple play that we have. We have a one story, 4 bedroom home and I've never had an issue with coverage or speed with comcast's Arris dual modem/router that we used for years. My speeds using comcast equipment were 150 Mbps down/5 mbps up. Nothing special, but it does the trick. I installed the Nighthawk, called comcast and activated it, checked connectivity and it was working fine. Very similar speeds using the speedtest.net. That was March 17th, last Saturday. On Sunday, March 18th, I noticed the internet was lagging quite a bit. I checked speedtest and it ran a 6 mbps download/5 mbps upload. I restarted the Nighthawk and tried again, but same result. I am lucky to get 10mbps. I'm not using another router, the placement of the Nighthawk is above anything else, not being blocked by metal or a wall, it's in the living room out in the open. I called comcast and they are sending a technician, but I'd like to try and fix it myself in case it's something you guys can help me with. Thanks for taking the time to read this, hope to see a good answer on here soon. Have a great night! Chef2.5KViews0likes4CommentsRN314 Disk corruption
I've had this RN314 for a few yeras now but its been nothing but headaches, Right now Its holding my data hostage. It Keeps telling me error 0x80070570 The File or Data is corrupted - I am running the NAS as a Raid-5 so i had hopes that a scrub should fix this issues. But it did not. Ther are no disk errors in Smart. I am currently Migrating my data to the cloud If this was only 1 or 2 files no big issues but as of now its over 20% of all the files on the drive. The good news is the files seem to still be playable and work for me if i manually navigate to them... If this was windows I'd run a check Disk on them, but I dont know what to do with this RN. HELP.Cannot get router to reconized LB2120 in wan
LTE 4g Modem LB 2120 Modem works great on AT&T whe connected on LAN side but when connected to any router by WAN port, it is not reconized. Tried in Bridge mode but no go. It is being advertised to work with a router but I have not found any setup instructions for this purpose nor have I found anyone who has every got it to work this way.Cannot access my router settings (log-in) in any way (factory reset'd several times)
Hey everyone, before I start I want to apologize if this is not the correct section to post this thread. The router I currently own is this one (click here) and I simply cannot access my router settings (routerlogin.com or 192.168.1.1) I do get the text box to input my username : password but all the login infos I've looked up in google won't work. Text Box I get to see. I tried multiple sites to check for login info and none work, one of those being this huge "2018 updated" list: https://www.lifewire.com/netgear-default-password-list-2619154 At the beggining I thought it could be my router messing stuff around because sometimes I got a message saying "Your conenction is not secure" so I tried on MS Edge and then on Firefox, no luck either. I decided to contact ISP, blah, blah, for security reasons they cannot give me admin : password (not sure why?) [My ISP provided me this Netgeat router, I didn't buy it by myself]. Anyhow I did not care about what they said because I used to have TrendNET router and could access to my router settings with no interference from them; the next big step I did was holding the little "factory reset" until the power light started to blink (Not sure if it's held more time it might do something). After factory reset I got the default SSID and PW of the network, I logged in, and had to "log-in" to the network, the only thing it said was the SSID and PW I already knew and 2 buttons, one was to print all the info and the other one to proceed and "activate" the internet. Tried all the possible combinations of admin : password after factory reset and no luck either, no I'm stuck with a SSID called "SureWest-f1" instead of the custom SSID I want. I remember once after a while (because I gave up and submitting a live chat here required a proof of purchase which I don't have because like I mentioned before, my ISP gave this to me) I remember attempting to factory reset it again like 4+ times, and only ONE of them allowed me to access the router info, I had like 3 options to choose, continue with net, configure settings, etc. (instead of the print thing screen I mentioned before) but amazingly unlucky me something happened and after settings everything I wanted, the save button or whatever it was simply didn't work, didn't have connection anymore, had to factory reset again and since then I haven't ever been able to access my router settings apart from that lucky try. (Not exactly sure WHAT I did that one time, maybe I held the factory reset button longer? Who knows..) I'd really like to access my router settings to change SSID how I want, custom password, and doing some port-forwarding. Please any help is appreciated, my ISP just won't help me, they're limiting me what to do with my OWN router.SolvedRBK44 System Unstable
60% of the time it works everytime! With each firmware update I feel like Netgear is getting further and further away from stability. I am so frustrated by this system that I don't know what to do at this point. If it were not for the fact that I have spent $400 including an extra stellite (RBS50) I would trash it and start over. I just manually updated to the beta firmware version 2.1.3.6 in hopes of finding stability. 2 hours into it and I can't tell you how many times I have rebooted the router and statellites. My family is ready to execute me in my sleep. Pleassssse Netgear! Fix the stability issues.Wifi extender EX6150v2 connection problems Help!
Hi, We have used this extender successfully for several months. We recently upgraded to NBN so have a new wifi router. We have followed video and connected it to new router using Ethernet cable. The Netgear extender is connected via Ethernet cable in our shed. When we try to connect to it, it picks up our correct wifi network but when we enter the wifi password it says we cannot join! What do we do?828Views0likes1CommentQuestions about the ReadyNAS 424
I am new here and am concidering getting a Netgear ReadyNAS 424. I currentley have a Asustor AS-5004T and want to upgrade it to something better what must incldude native windows based File versioning support (Previous Versions) for SMB shares held on the NAS. My current setup is as follows, I have 2 x 6TB WD Red Pro HDD's inside my exsiting NAS box confiqured in RAID 1 along with a 4TB Red Pro drive used for weekley archiving. I also have a another 6TB WD Red Pro HDD inside my Windows 2016 Essentials rack server what acts as a backup to my main 6TB RAID 1 array. I have a few questions about the ReadyNAS 424, and hopefully those reading will be able to ansewer for me. 1) Can the RAM on the ReadyNAS 424 be upgradded, and if so to how much and what type? I have 8GB in my AS-5004T at the moment and is of the 1600MHz DDR3L SO-DIMM type. (Will 2GB be enough!? , my NAS is my main storage for daily usage and not just a backup/archive) 2) At what level does the ReadyNAS 424 support DFS and file versioning. I would like it to idealy integrate with the DFS capabilitys of Windows Server and have the 6TB drive inside my Rack Server cross syncronise the SMB shares on the ReadyNAS 424 ? 3) Does the ReadyNAS 424 support 802.3AD link aggregation? (I have a Draytek VigorSwitch P2261) 4) How reliable is the ReadyNAS 424?, I am allways having reliability isues with SMB shares shared via UPnP on my Asustor NAS box to my Denon network audio streamer that is part of my Hi-Fi. Sometimes it works fine, othertimes my Denon network audio streamer cannot see the shares on my Asustor NAS box! (All hard wired, no Wi-Fi or Mains LAN senders) 5) Does the ReadyNAS 424 support share/folder encryption what has to be unlocked by a password on starting the unit up. (In case the unit gets stolen.) Also, below suggests that ReadyNAS OS6 supports DFS, what I thought was a proprietary technology to Windows and was not available on Linux based NAS boxes? https://kb.netgear.com/23090/How-do-I-use-DFS-feature-on-the-ReadyNAS-OS-6-storage-system Lastly , anythoughts on the ReadyNAS 424 in general? Regards: Elliott.EX2700 i cant remember login or security answers
ive got a new internet recently so ive had to reconnect my extender and it is asking me to login, i cant remember the username let alone the password so i clicked username and password help and its security question, sisters name and best friends name, im definitely not getting those questions wrong but it says i am and often times it just comes up with timestamp has expired please return to menu, any ideas how i get round all this?1.8KViews0likes1Comment
