gch
Apr 21, 2017Aspirant
AirCard 785S problems: DHCP not working, factory reset not possible, does not connect to to mobile n
I have an AirCard 785S, no network lock, bought in Italy and working perfectly for about 6 months both in Italy and Germany. Suddenly a message "Update failed" appeared. I never asked for an OTA...
stevesw
Apr 23, 2017NETGEAR Expert
Hi,
Can you please confirm what AC785 SKU you have.
SKU version is printed on label under the battery.
If you purchased the unit in Europe, then it is unlikely that you bought a Telstra SKU.
The firmware download link you've referenced will only work on Telstra SKU'd devices.
What state is the unit currently in?
Does it power up and can you access the internal web page on 192.168.1.1?
If so, can you confirm the firmware version currently on the device.
And can you check that your APN is still set correctly.
Thanks
Steve
- gchApr 24, 2017Aspirant
Hi, thanks for the reply.
The unit is:
NetGear Aircard 785SSKU: AC785-100EUSTA: 100-19123-01R15bought in Italy.
As I said in my post,
- The unit boots
- I can connect to it throuth USB tethering, but only IF I set a fixed IP in my laptop
- This is the info output (private infor blanked out):
Account Details
My number:
IMEI: *******
ICCID:
IMSI:
WiFi Details
MAC Address: 40-5D-82-C6-DA-D3
WiFi Range: Short
WiFi Devices: 0
Main WiFi
WiFi name: ****
WiFi password: ***
Encryption: WPA2_Personal_AES
Mode: M802_11_BGN
Band: 2.4 GHz
Bandwidth: HT20
Max WiFi Devices: 10
Broadcast Network Name: false
Firmware
FW Version: NTG9X25A_02.14.04.13
FW Build Date: 05/03/16
Web App Version: AC785S-1_03.03.103.110
Bootloader Version: NTG9X25A_02.14.04.13
Hardware Version: 1.0
TRU-Install: PHS_B4045
Device
Model: AirCard 785S
AC785S-100
Manager: http://netgear
PRI
Version: 9903883, 01.20
Power State: Online
Current temperature: 29°C
Current voltage: 4087mV
Battery charge level: 74%
Battery status: Normal
Battery temperature: 31
WWAN Info
IP Address: 0.0.0.0- I cannot change ANY parameter in the configuration:
- I can set a new value for a parameter in the web UI
- I save it (apparently)
- It does the usual reboot
- After the reboot everything is back as before: apparently it cannot write the new value in the memory
- I CANNOT do a factory reset: it say "shutting down", but it gets stuck there forever, until the battery is flat or I remove it.
- The APN is correct, but this has also nothing to do with the problem.
The device should be able (and it was able) to deliver a DHCP IP also if I am not connected to the GSM/LTE network. - Anyway, it stays forever in "connecting"
Thanks for the help.
