Retired_Member
Aug 04, 2015Aircard 785s Speed and Firmware Update Problem
Hi *, I just bought a Aircard 785s in Germany. I am actually using it in my holidays in Austria and I am very unhappy with it. Problems: * Reception: Switching the device on, it is quite fast...
nhann
Aug 05, 2015NETGEAR Employee Retired
Hi Ray_,
Please refer to the Downloads and Documentation page to manually upgrade your 785S: http://kb.netgear.com/app/answers/detail/a_id/25067
Under "Software", download the driver and software listed.
Under "Documentation", follow the instructions in the Firmware Upgrade Procedure: http://www.downloads.netgear.com/files/aircard/AC_785S_Telstra/FW_Upgrade_Procedure_AirCard%20785S.PDF
Let us know how it works for you.
NhanN
- trancedroidAug 24, 2015Aspirant
I just want to tell you that you're a moderator for NETGEAR and you're giving wrong instructions. I've downloaded the same firmware and it's not working because the device is a RETAIL UNLOCKED. So please stop confusing people.
