Squirt
Oct 14, 2015Aspirant
Aircard 785s won't turn on
4 months old aircard 785s will not turn on , will not charge or connect with PC via USB . there is nothing wrong with the lead or the charger. Currently trying to get phone support to return under ...
- Oct 14, 2015
Hello Squirt
I have sent you a Private message about your case.
DarrneM
DarrenM
Oct 14, 2015Sr. NETGEAR Moderator
Hello Squirt
DarrneM
- dim-Oct 25, 2015Aspirant
Hello, I have a similar problem. I can turn the device on, but the battery won't charge neither from the wall socket nor from the computer. How to solve this problem?
- SquirtOct 27, 2015Aspirant
WIll yours turn on with the device plugged in to the mains, with the battery removed?
Sounds like you have a duff battery.
- dim-Nov 02, 2015Aspirant
Yes, it turns on with and w/o battery when plugged into the mains. Probably dead battery indeed. Do you know if I can send it backfor replacement somewhere?
