Squirt
Oct 14, 2015Aspirant
Aircard 785s won't turn on
4 months old aircard 785s will not turn on , will not charge or connect with PC via USB . there is nothing wrong with the lead or the charger. Currently trying to get phone support to return under ...
- Oct 14, 2015
Hello Squirt
I have sent you a Private message about your case.
DarrneM
dim-
Oct 25, 2015Aspirant
Hello, I have a similar problem. I can turn the device on, but the battery won't charge neither from the wall socket nor from the computer. How to solve this problem?
Squirt
Oct 27, 2015Aspirant
WIll yours turn on with the device plugged in to the mains, with the battery removed?
Sounds like you have a duff battery.
- dim-Nov 02, 2015Aspirant
Yes, it turns on with and w/o battery when plugged into the mains. Probably dead battery indeed. Do you know if I can send it backfor replacement somewhere?
